TwinTurbo.NET: Nissan 300ZX forum - BB turbos require less oil than standard bearing turbos.
MikeH(Twin GT35BB Incon Z)
on April 20, 2003 at 12:24 AM
What weight oil are you running?
posted by ZHOUND
on April 20, 2003 at 12:09 AM
I run restriction in the oil lines to reduce oil flow.
BB turbos still spinning after engine shut off..
22:54:43 04/19/03
same principle as mufflers smoking after car shuts off, no? (n/m)
ZEngineer
22:57:31 04/19/03
Or gow a fan spins after shutoff... I would assume it means
yellowpearlz
23:35:37 04/19/03
shut up, you know you're just bragging that you have BB
shadowZ
23:54:28 04/19/03
Must be nice... :jealous: (n/m)
Kenny (10 psi)
23:57:16 04/19/03
ZHOUND
00:09:23 04/20/03
Not when it is hot. I run 10 w 40. (n/m)
00:19:00 04/20/03
Re: Not when it is hot. I run 10 w 40.
ZHOUND
00:23:05 04/20/03
Your rod bearing will thank you,
Chip(GinnMotorsports)
16:55:38 04/20/03
You just have to keep an eye on it.
ZHOUND
00:46:26 04/21/03
BB turbos require less oil than standard bearing turbos. -
00:24:42 04/20/03
BB Rules...
xybertron
13:28:04 04/20/03
